TwinTurbo.NET: Nissan 300ZX forum - what needs to be done?
Subject what needs to be done?
Posted by wickdGSXR on June 22, 2015 at 3:22 AM
  This message has been viewed 280 times.
In Reply To Thanks for all the info... posted by Jimmerz149 on June 21, 2015 at 01:41 PM
Message My engine hoist has been invaluable. I usually pull the Z motor out once every two years to inspect for exhaust leaks and crap.
Engine hoist, engine stand and a decent tool set you can do about anything. There is an online manual for your torque specs. The only work that I have had the machine shop do on this build is:
polish the crank & check clearances.
balance the Eagle rods & Ross pistons.
install +1mm valves, valve seals, springs & port.
hone cylinders and check clearances.
Just about everything else you can do at home and you learn your car. Definitely helps when having to troubleshoot.
