TwinTurbo.NET: Nissan 300ZX forum - Bleed it again there is still air in there. >>>>>
Subject Bleed it again there is still air in there. >>>>>
Posted by ZUL8TR on June 19, 2015 at 8:11 AM
  This message has been viewed 273 times.
In Reply To M/T won't go into gear after clutch replacement posted by Eagle7 on June 17, 2015 at 05:47 PM
Message How much top pedal play is there? Did you replace the shift lever ball?
The slave movement should be enough to completely disengage the clutch disk when the proper pedal adjustment is there and the system is bleed of all air. There is no spec on the slave travel.
ZUL8TR in Orlando,FL
