TwinTurbo.NET: Nissan 300ZX forum - M/T won't go into gear after clutch replacement
Subject M/T won't go into gear after clutch replacement
Posted by Eagle7 on June 17, 2015 at 5:47 PM
  This message has been viewed 339 times.
Message I am encountering a lot of problems lately. I've installed the JWT Clutch and Flywheel combo, bled the system (both upper and lower lines), adjusted the clutch pedal to its maximum height per SpecialtyZ's instructions and now I can't get into gear when the engine is running. There are no leaks. When i try to put it into gear it barely engages and the wheels start to spin.
Everything was fine with the stock setup.
Any help would be appreciated. Thanks
