TwinTurbo.NET: Nissan 300ZX forum - Hesitation 2-3K is usually a Knock Sensor thing..
Subject Hesitation 2-3K is usually a Knock Sensor thing..
Posted by Cjw3 on June 16, 2015 at 8:56 PM
  This message has been viewed 235 times.
In Reply To Code 45 injector leak and hesitation. Can't figure it out posted by JConcepTTZion on June 16, 2015 at 06:10 PM
Message What code do you have now?..
I'd get ECU talk ( Free ) and Consult Cable ( $35 or so ), and start looking at what the ECU is seeing..
If the ECU is pulling timing during the 2-3 range, you will see it in the ECU talk display.. and then you know you have a Knock or Knock sensor issue..
Do a compression test.. that will tell you if you have a '90 replacement engine..
Cj
