TwinTurbo.NET: Nissan 300ZX forum - Re: What to do while the engine is out/general questions
Subject Re: What to do while the engine is out/general questions
Posted by cremion on June 15, 2015 at 9:37 PM
  This message has been viewed 262 times.
In Reply To What to do while the engine is out/general questions posted by Z32CheekiBreeki on June 15, 2015 at 07:18 PM
Message Have a look at all your hoses; I ended up going to silicone everything with the exception of fuel. Speaking of, replace those. Don't forget the one connecting your fuel rail and the ones going up the driver's side. Brittle hoses (no matter what it is) are the worst!
If you're deleting the carbon canister, may as well get rid of the 3rd fuel line going back to the tank; put a one-way on the remnant of the 3rd line so that you don't have vapor build-up and crap doesn't go back in.
Delete your secondary clutch bleeder; you can either put a block on the 3-way or swap the 3-way for a 2-way. Simplifies bleeding the clutch quite a bit. If you add a speedbleeder, you can bleed your clutch system inside of 10 min. It's amazing.
If you're checking out 3" downpipes, consider MSP manifolds. The difference between oem and aftermarket isn't clearly visible in pics. Holding them side by side is hilarious.
PS pump- I actually ran a return line that runs along the front subframe and goes straight up the side. Didn't end up getting the metal pipe that normally goes around the front.
Relocate PTU.
