TwinTurbo.NET: Nissan 300ZX forum - Re: Turbo coolant lines,two on each side. They get
Goldeneye63
on June 11, 2015 at 6:46 PM
posted by ttz'in (norcal)
on June 11, 2015 at 05:09 PM
It's not a small leak it's big enough so that when I squeeze the coolant line coming from the radiator I can hear. Oolant leaking and when I crank it it flows out...
Help my 89 300zx wont start
Goldeneye63
12:47:24 06/11/15
You said you changed the CAS, what about the PTU?
Woody75 (Denver)
13:41:14 06/11/15
Re: You said you changed the CAS, what about the PTU?
Goldeneye63
13:50:05 06/11/15
is it cranking so starter is not the issue? What about >>
ZUL8TR
14:20:16 06/11/15
Re: is it cranking so starter is not the issue? What about >>
Goldeneye63
14:29:47 06/11/15
There are coolant lines under the intake plenum
ttz'in (norcal)
14:56:52 06/11/15
Re: There are coolant lines under the intake plenum
Goldeneye63
16:43:20 06/11/15
ttz'in (norcal)
17:09:32 06/11/15
Re: Turbo coolant lines,two on each side. They get -
Goldeneye63
18:46:38 06/11/15
Maybe one of the lines burst or a clmp came off. Check the
YlwPrlZTT
20:21:49 06/11/15
Re: Maybe one of the lines burst or a clmp came off. Check the
Goldeneye63
00:47:51 06/12/15
Good Idea Inside >>>>>
ttz'in (norcal)
08:31:47 06/12/15
Battery
Goldeneye63
13:28:19 06/12/15
Remove it and bring to local auto store for testing (n/m)
FrozTTy
09:59:53 06/15/15
You can delete your duplicate post since nobody has replied. (n/m)
Nate (NoVA)
11:28:26 06/12/15
