TwinTurbo.NET: Nissan 300ZX forum - If a SR20 really drops 300 lbs, factor in suspension
Subject If a SR20 really drops 300 lbs, factor in suspension
Posted by flashstar on June 10, 2015 at 2:46 AM
  This message has been viewed 353 times.
In Reply To Re: SR2.0 swap posted by danvan on June 09, 2015 at 10:00 PM
Message work too. You will have to compensate for such a large weight change with different springs and valving. Plan on spending at least $1000 on coilovers if you go that route.
Since you'd be dropping weight only at the front, your car will be pretty rear-biased. I'd go as far as to weigh and corner-balance after all is said and done. What fun is the power if you can't turn a corner for beans?
What about maintenance and local parts availability later? Swapping in a JDM-only engine is just a pita.
