TwinTurbo.NET: Nissan 300ZX forum - It's the Green/Red.. Lt Green/Red wire set
Subject It's the Green/Red.. Lt Green/Red wire set
Posted by Cjw3 on June 08, 2015 at 7:47 PM
  This message has been viewed 304 times.
In Reply To Re: 15 Is only at Idle.. posted by Goldchocobo on June 08, 2015 at 07:27 PM
Message no matter what the TPS Voltage is, it will not hit 'Idle Mode' until the Idle Switch is made..
I had an ECU in a Car that would not recognize the Idle Switch, even when it was made.. ECU Talk could not see it through the ECU.. Swapped out ECU's and then it would idle..
So just because the Wire's are made, does not mean the ECU will actually respond,,
It's great being able to see that the ECU is seeing.. make the world much clearer .. ECU Talk is great..
Cj
