TwinTurbo.NET: Nissan 300ZX forum - Re: 15 Is only at Idle..
Subject Re: 15 Is only at Idle..
Posted by Goldchocobo on June 08, 2015 at 7:27 PM
  This message has been viewed 298 times.
In Reply To 15 Is only at Idle.. posted by Cjw3 on June 08, 2015 at 06:53 PM
Message Funny you mention the TPS. Yesterday, I got the Z to operating temp, and checked the timing. Still 15btc. I then checked the TPS with the voltmeter, and it was at .75v on an idle of 750. Obviously that was incorrect, so I set the TPS down to .45v.
The ignition timing remained the same, however. Perhaps I need to reset the ecu, or try again today since the engine's cooled down.
Is there any way I can test the Idle Switch?
