TwinTurbo.NET: Nissan 300ZX forum - 15 Is only at Idle..
Subject 15 Is only at Idle..
Posted by Cjw3 on June 08, 2015 at 6:53 PM
  This message has been viewed 276 times.
In Reply To Ignition timing issues posted by Goldchocobo on June 08, 2015 at 04:11 PM
Message IF the car was not sitting on the 'Idle Switch' ( In the TPS ) then you will LIKELY have an Ignition in the 25-30 range and wandering..
I do not think you were in 'Idle Mode'..
I'd put the Ignition back, as you likely are running the Ignition very retarded.. and things will get HOT..
Use ECU Talk to read the TPS Voltage, or Check for TPS Switch..
Else you can do the Voltmeter trick to see the TPS Voltage..
Cj
