TwinTurbo.NET: Nissan 300ZX forum - Just coat with non synthetic engine oil that will be used >>
Subject Just coat with non synthetic engine oil that will be used >>
Posted by ZUL8TR on June 07, 2015 at 4:18 AM
  This message has been viewed 323 times.
In Reply To Fresh overbore + Wiseco pistons, how to store block? posted by james92se on June 06, 2015 at 01:56 PM
Message for break in. Then cover with some plastic rap. Is the oil pan on? Might want to put it on, ,if no wrap the whole engine.
Not a fan of WD40 it is not an oil.
I assume you super cleaned the cylinders with hot water and soap till no residue when wiped with paper towel then oiled them up before piston and rings install?
ZUL8TR in Orlando,FL
