TwinTurbo.NET: Nissan 300ZX forum - My OEM, stock length rear studs are 46mm. Source: my caliper
Subject My OEM, stock length rear studs are 46mm. Source: my caliper
Posted by flashstar on June 06, 2015 at 12:13 AM
  This message has been viewed 278 times.
In Reply To sawbonez says 46mm, then they say Bernie says 50mm, posted by XTZ on June 05, 2015 at 05:45 PM
Message Believe me, I've pulled in a bunch in the past. If you go longer, you'll need to cut a hole in the rear cover or pull the hub. Longer studs will not fit in between the rear dust cover and hub.
