TwinTurbo.NET: Nissan 300ZX forum - Have a boost leak tester? That'd be my next step. (n/m)
spicyZ
on June 03, 2015 at 2:39 PM
Don't think it's a pinched ring...
posted by Auggie
on June 03, 2015 at 12:46 PM
Won't Idle
Auggie
11:32:55 06/02/15
And I checked all accessible vacuum lines: good-to-go
Auggie
11:35:51 06/02/15
check the connectors on your IACV, again old harness
YlwPrlZTT
12:38:21 06/02/15
I originally cleaned the AAV spades way back when...
Auggie
12:38:30 06/03/15
Five year old fuel, seriously ? Hope it's not very
ttz'in (norcal)
14:27:26 06/02/15
Tank was over half-full
Auggie
09:50:15 06/03/15
Add some dry-gas, hopefully not too much water in lines (n/m)
FrozTTy
09:52:32 06/03/15
Ordered some Iso-Heet from Amazon.
Auggie
12:40:46 06/03/15
I would pull the plugs and inspect for excess fuel
spicyZ
12:32:53 06/03/15
Auggie
12:46:54 06/03/15
Have a boost leak tester? That'd be my next step. (n/m) -
spicyZ
14:39:00 06/03/15
I assume you mean "vacuum" test?
Auggie
15:55:02 06/04/15
Not what I meant
spicyZ
21:21:48 06/04/15
When you check the injector operation also ohm them >>
ZUL8TR
03:32:38 06/04/15
"Wholesale" meaning I replaced all of them at once.
Auggie
15:32:13 06/04/15
Fresh fuel yet ? (n/m)
ttz'in (norcal)
16:54:52 06/04/15
You can check injector resistance at the ECU side
spicyZ
08:28:58 06/08/15
Sounds like the engine is flooding
DAYTONAZ
18:02:11 06/04/15
Running rich at idle would be a better description (n/m)
DAYTONAZ
18:10:25 06/04/15
Re: Won't Idle
kbilow
20:11:42 06/04/15
It really still sounds to me like a an electrical connection
YlwPrlZTT
23:32:43 06/04/15
Check Madkiwi's above SOLVED post for ideas (n/m)
OverZealous (CT)
21:38:28 06/05/15
