TwinTurbo.NET: Nissan 300ZX forum - I say cap/block/whatever the ports on the exhaust cover
Subject I say cap/block/whatever the ports on the exhaust cover
Posted by LivinTheDream on June 03, 2015 at 12:26 PM
  This message has been viewed 303 times.
In Reply To Exactly...and let me intake valve ports breath. posted by evan_aggie on June 02, 2015 at 01:23 PM
Message Block or add barb fittings where the actual pcv valves are on the plenum to use for clean routed vacuum source (recirc valves). And leave the intake valve cover ports routed to the turbo inlet. Or put a catch can between the intake valve cover ports and the turbo inlets. The vacuum is a big help and this method is supported by SZ.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
