TwinTurbo.NET: Nissan 300ZX forum - fixed! connector corrision with sub-harness!
Subject fixed! connector corrision with sub-harness!
Posted by Auggie on May 30, 2015 at 5:08 PM
  This message has been viewed 411 times.
In Reply To Re: Car won't start after replacing injectors posted by Placuch on May 30, 2015 at 04:03 PM
Message It was corrosion on the sub-harness spade terminals; specifically, the ground spade.
Even though the corrosion was uniform on all terminals, only on the ground did it prevent any continuity to the PTU; connection to the coils were not adversely affected, with ~1.5 Ohm resistance.
Scrubbing with a wire brush followed with electrical contact cleaner and I got ~2 ohms to the PTU for ground. Reassembled everything and the car fired up the first crank!
Now I have a single misfire to resolve, but dang, I'm glad I was able to troubleshoot this on my own, allowing to learn more intimately the ignition and the electrical system in general.
When I replace the entire EFI wiring harness as I replace the turbos, that should do away with any further electrical gremlins!
