TwinTurbo.NET: Nissan 300ZX forum - Check all the PTU connections that it calls for.
YlwPrlZTT
on May 30, 2015 at 3:04 PM
I agree with all
posted by Auggie
on May 30, 2015 at 02:47 PM
If all your readings are off chances are you're doing something wrong, if at least one test gives what you're looking for but not the others maybe the PTU is bad. It's hard to tell.
Car won't start after replacing injectors
Auggie
14:15:17 05/29/15
Won't crank, or cranks but won't fire up? (n/m)
FrozTTy
15:24:44 05/29/15
Re: Won't crank, or cranks but won't fire up?
Auggie
15:30:18 05/29/15
You could always check each plug individually. Remove the
YlwPrlZTT
16:08:12 05/29/15
Will do that with the coils!
Auggie
17:23:01 05/29/15
you don't have to mess with the fuel line to get the balance
YlwPrlZTT
19:57:01 05/29/15
Make sure fuel lines aren't crossed...
ttz'in (norcal)
20:13:03 05/29/15
Matched photos with other cars
Auggie
08:05:39 05/30/15
No Spark
Auggie
10:16:11 05/30/15
Also, ~1.2-1.5 Ohms
Auggie
10:48:24 05/30/15
Actually, twas 0.9 Ohms
Auggie
12:43:49 05/30/15
And Ignition Coil Relay good
Auggie
11:13:32 05/30/15
Could be PTU?
Auggie
13:23:37 05/30/15
Do you still have the PTU subharness installed?
YlwPrlZTT
14:06:01 05/30/15
Yes, but harness very pliable relative to all else
Auggie
14:17:27 05/30/15
Ok, I would still delete that subharness to be sure. It's
YlwPrlZTT
14:39:11 05/30/15
I agree with all
Auggie
14:47:06 05/30/15
Check all the PTU connections that it calls for. -
YlwPrlZTT
15:04:04 05/30/15
I actually just deleted my subharness as well, once I get
YlwPrlZTT
15:05:47 05/30/15
With an older EFI harness, and in the PTU area
ttz'in (norcal)
15:15:32 05/30/15
Don't think it's PTU
Auggie
15:48:14 05/30/15
Re: Car won't start after replacing injectors
Placuch
16:03:46 05/30/15
Re: Re: Car won't start after replacing injectors (n/m)
Auggie
16:22:53 05/30/15
My GAWD
Auggie
16:27:06 05/30/15
fixed! connector corrision with sub-harness!
Auggie
17:08:51 05/30/15
Glad you got it running again. That sub-harness is nothing
YlwPrlZTT
17:16:41 05/30/15
Agree with sub-harness PITA!
Auggie
17:44:57 05/30/15
I would avoid Wiring Specialties
flashstar
13:50:48 05/31/15
^ Agree ^ Well done ! (n/m)
ttz'in (norcal)
14:50:11 05/31/15
