TwinTurbo.NET: Nissan 300ZX forum - Actually, twas 0.9 Ohms
Subject Actually, twas 0.9 Ohms
Posted by Auggie on May 30, 2015 at 12:43 PM
  This message has been viewed 356 times.
In Reply To Also, ~1.2-1.5 Ohms posted by Auggie on May 30, 2015 at 10:48 AM
Message I found the accurate way to measure coils by pulling the connector off and testing pins 1 and 2 of the coil: they all measure 0.9 Ohms.
Spec says 0.7 Ohms, so not sure if that 0.2 Ohm difference is enough to prevent any of the coils to fire. I pulled #2 coil and plug and physically ground the threaded body to the ground screw on back of manifold with alligator clips on a jumper wire and still didn't perceive a spark.
