TwinTurbo.NET: Nissan 300ZX forum - And Ignition Coil Relay good
Auggie
on May 30, 2015 at 11:13 AM
No Spark
posted by Auggie
on May 30, 2015 at 10:16 AM
Applied 12V to pins 1 and 2, got audible click and measured ~1.5 Ohms across pins 3 and 5.
Car won't start after replacing injectors
Auggie
14:15:17 05/29/15
Won't crank, or cranks but won't fire up? (n/m)
FrozTTy
15:24:44 05/29/15
Re: Won't crank, or cranks but won't fire up?
Auggie
15:30:18 05/29/15
You could always check each plug individually. Remove the
YlwPrlZTT
16:08:12 05/29/15
Will do that with the coils!
Auggie
17:23:01 05/29/15
you don't have to mess with the fuel line to get the balance
YlwPrlZTT
19:57:01 05/29/15
Make sure fuel lines aren't crossed...
ttz'in (norcal)
20:13:03 05/29/15
Matched photos with other cars
Auggie
08:05:39 05/30/15
No Spark
Auggie
10:16:11 05/30/15
Also, ~1.2-1.5 Ohms
Auggie
10:48:24 05/30/15
Actually, twas 0.9 Ohms
Auggie
12:43:49 05/30/15
And Ignition Coil Relay good -
Auggie
11:13:32 05/30/15
Could be PTU?
Auggie
13:23:37 05/30/15
Do you still have the PTU subharness installed?
YlwPrlZTT
14:06:01 05/30/15
Yes, but harness very pliable relative to all else
Auggie
14:17:27 05/30/15
Ok, I would still delete that subharness to be sure. It's
YlwPrlZTT
14:39:11 05/30/15
I agree with all
Auggie
14:47:06 05/30/15
Check all the PTU connections that it calls for.
YlwPrlZTT
15:04:04 05/30/15
I actually just deleted my subharness as well, once I get
YlwPrlZTT
15:05:47 05/30/15
With an older EFI harness, and in the PTU area
ttz'in (norcal)
15:15:32 05/30/15
Don't think it's PTU
Auggie
15:48:14 05/30/15
Re: Car won't start after replacing injectors
Placuch
16:03:46 05/30/15
Re: Re: Car won't start after replacing injectors (n/m)
Auggie
16:22:53 05/30/15
My GAWD
Auggie
16:27:06 05/30/15
fixed! connector corrision with sub-harness!
Auggie
17:08:51 05/30/15
Glad you got it running again. That sub-harness is nothing
YlwPrlZTT
17:16:41 05/30/15
Agree with sub-harness PITA!
Auggie
17:44:57 05/30/15
I would avoid Wiring Specialties
flashstar
13:50:48 05/31/15
^ Agree ^ Well done ! (n/m)
ttz'in (norcal)
14:50:11 05/31/15
