TwinTurbo.NET: Nissan 300ZX forum - You could always check each plug individually. Remove the
Subject You could always check each plug individually. Remove the
Posted by YlwPrlZTT on May 29, 2015 at 4:08 PM
  This message has been viewed 401 times.
In Reply To Re: Won't crank, or cranks but won't fire up? posted by Auggie on May 29, 2015 at 03:30 PM
Message coil, insert the spark plug into the coil, ground it, and have someone crank the car while you look at the plug. You should see if it's firing or not. Just do it for each one. As far as the plenum goes I feel your pain. Have you thought about bypassing the plenum water lines? It makes pulling the plenum feel like an oil change, literally a 45 min job if that.
