TwinTurbo.NET: Nissan 300ZX forum - Re: Won't crank, or cranks but won't fire up?
Subject Re: Won't crank, or cranks but won't fire up?
Posted by Auggie on May 29, 2015 at 3:30 PM
  This message has been viewed 372 times.
In Reply To Won't crank, or cranks but won't fire up? (n/m) posted by FrozTTy on May 29, 2015 at 03:24 PM
Message Cranks, but doesn't start.
Not sure how to test coil wires and fuel injectors for power during crank.
Worse case scenario is re-pull the plenum entirely (ugh) then with a multimeter, check ground continuity for each injector wire, knowing that there must be on and only one wire to ground, then check the other wire for continuity up stream of the splice.
Haven't looked at how to check the 3 wires going to each coil...
