TwinTurbo.NET: Nissan 300ZX forum - Transmission woes
Subject Transmission woes
Posted by Attridge_300ZX on May 28, 2015 at 11:17 PM
  This message has been viewed 347 times.
Message Last fall I had my clutch pedal sink to the floor. I found the culprit, a broken pivot ball. It also took out the slave cylinder, and clutch fork clips.
I replaced the clutch fork and pivot ball with ones form an 05 350Z as that's what's used in the Heavy Duty clutch fork kits sold by vendors. I installed everything, put the transmission back on, and adjusted the clutch pedal.
However now I can't seem to get into 1st or 3rd, and really none of the other gears are too smooth. I changed the tranny fluid and these parts came out in the old oil. Bits
So I'm wondering if i have a bigger problem on my hands than I had originally thought. Any insight would be appreciated!
