TwinTurbo.NET: Nissan 300ZX forum - wastegate pressure
Subject wastegate pressure
Posted by EngineerLV on May 26, 2015 at 4:17 PM
  This message has been viewed 325 times.
In Reply To GT600 turbo actuator adjustment initial setting - help posted by Quick_Z on May 26, 2015 at 02:49 PM
Message You want to hook up your wastegates and use a pressure gauge and air compressor to test them. Set them so they both open at the same pressure. 13-15 is what I have mine set at, you can always go higher with a ebc, but you want to keep the base low in case you start to detonate before tuning is sorted out at lower psi.
