TwinTurbo.NET: Nissan 300ZX forum - GT600 turbo actuator adjustment initial setting - help
Subject GT600 turbo actuator adjustment initial setting - help
Posted by Quick_Z on May 26, 2015 at 2:49 PM
  This message has been viewed 479 times.
Message For new z1 adjustable gt600 wastegate actuators, should they be left as adjusted when you receive them, or should I adjust those to a specific setting before installation? It looks like it will be difficult to get to them to re-adjust later once they're installed. At what pressure should the spring pre-load be set to fully open if one wants to be able to keep the wastegates closed up to the max safe pressure setting (24-26 psi?) later with a boost controller? Should they fully open at about 14-15 psi, lower or higher?
Thanks for any suggestions
