TwinTurbo.NET: Nissan 300ZX forum - gt600 / ms manifolds Installation questions - help
Subject gt600 / ms manifolds Installation questions - help
Posted by Quick_Z on May 26, 2015 at 2:44 PM
  This message has been viewed 270 times.
Message When installing new z1 gt600r bb turbos, can the oem/stock turbo heat shields be installed on those? I don't see that the original heat shield brackets will fit on the gt600 compressor housing, but I'm sure one of the bolts on the back of the compressor housing can be removed to add the oem bracket. However, it seems that the back of the bolt actually goes all the way through the compressor housing so it can be seen on the inside of the compressor discharge piping. Is it safe to remove one of these bolts and re-install, as far as leaks may go, should I observe any specific directions or warning?
