TwinTurbo.NET: Nissan 300ZX forum - Problem was a stuck check valve.
Subject Problem was a stuck check valve.
Posted by JMartz on May 26, 2015 at 6:16 AM
  This message has been viewed 297 times.
In Reply To I have the same situation... let me know what you find plz (n/m) posted by FrozTTy on May 25, 2015 at 12:24 PM
Message Near the nozzle there is a small check valve to prevent the fluid from returning to the reservoir and emptying the hose. This way when you use the system water squirts immediately. I removed the hatch panels and disconnected the hose just past the pump. Applied pressure with a compressor hose, using a rubber tipped blow nozzle and the check valve released. Let us see now how long it works. Valve may need replacement.
