TwinTurbo.NET: Nissan 300ZX forum - It depends on whether her husband has a gun ;-) (n/m)
Zuberman
on May 25, 2015 at 6:22 AM
It has been said that most engine wear is at start up. >>
posted by ZUL8TR
on May 25, 2015 at 04:17 AM
shaking steering wheel under braking
shawnc
09:34:24 05/23/15
looks as if all the obvious issues have been address. Just
jzack
10:53:59 05/23/15
What if the new MC isn't applying equal pressure to the
jzack
11:01:32 05/23/15
I'll check the TR again, but I did the replacement in '05ish
shawnc
11:13:02 05/23/15
Re: looks as if all the obvious issues have been address. Just
ttz'in (norcal)
13:53:04 05/23/15
Did you bleed system per FSM, which includes
ttz'in (norcal)
13:56:22 05/23/15
Bled correctly per FSM. Usually 88-90ft-lbs star pattern.
shawnc
14:31:51 05/23/15
Sounds like your on top of things, start with BMC.
ttz'in (norcal)
14:58:46 05/23/15
You didn't mention if you torqued all the lug nuts the
Zuberman
14:49:22 05/23/15
Check the lateral runout of the tire, the rim and the >>
ZUL8TR
04:19:50 05/24/15
I re-torqued wheels to 75ft-lbs. The last alignment shop I
shawnc
09:15:54 05/24/15
My hotshot alignment guy here, (decades in the biz) told me
Zuberman
14:19:18 05/24/15
ZUL8TR
04:17:18 05/25/15
It depends on whether her husband has a gun ;-) (n/m) -
Zuberman
06:22:09 05/25/15
Agreed. Those are things I try to explain to people. You run
Zuberman
06:23:25 05/25/15
