TwinTurbo.NET: Nissan 300ZX forum - Oil and Fuel Line Questions
Subject Oil and Fuel Line Questions
Posted by Bigwill837 on May 24, 2015 at 2:51 PM
  This message has been viewed 654 times.
Message Hey team. I’m plumbing some fuel and oil lines. I have a few questions about fittings. When do you need to use a rubber o-ring or a crush washer?
I noticed the Z1 Full Flow Oil Cooler setup, as well as most aftermarket oil coolers, use a rubber o-ring or a crush washer when going from A/N adapter fitting to the cooler or sandwich plate (1/2" NPT or -12AN). What’s the rule? As long as it goes from 37* A/N flare to 37* A/N flare, you don’t need an o-ring or washer?
My BDE fuel rails came with o-ring adapter fittings from the rail to the -6AN male outlet. Does the same hold true for fuel? As long as it goes from A/N flare to A/N flare, you don’t need a o-ring or washer?
When do you use the crush washers and when do you using the o-rings?
  • Oil and Fuel Line Questions - Bigwill837 14:51:30 05/24/15
