TwinTurbo.NET: Nissan 300ZX forum - Bled correctly per FSM. Usually 88-90ft-lbs star pattern.
Subject Bled correctly per FSM. Usually 88-90ft-lbs star pattern.
Posted by shawnc on May 23, 2015 at 2:31 PM
  This message has been viewed 271 times.
In Reply To Did you bleed system per FSM, which includes posted by ttz'in (norcal) on May 23, 2015 at 01:56 PM
Message Car also has 300deg camber plates and Z1 10mm hubcentric spacers with longer lugs (needed them for the BBK). Again, the shaking didn't start until I changed out the BMC and put the car back on the ground for zdayz
