TwinTurbo.NET: Nissan 300ZX forum - shaking steering wheel under braking
Subject shaking steering wheel under braking
Posted by shawnc on May 23, 2015 at 9:34 AM
  This message has been viewed 422 times.
Message Heavy vibrations under braking conditions seemed to have started after I replaced my brake master cylinder.
Recent maint:
New BBK all around, so no warped rotors.
Tension rods with urethane bushings have maybe only 30k miles on them.
Jacked the car up, no free play in the wheels so i suspect bearing are good.
After doing an EVO bbk that felt fine except for a slightly soft/long pedal throw, I switched to the proper 17/16" BMC and flushed all the lines again and that's when I noticed the vibrations on braking.
More info: 91TT 80k miles. Good condition shocks/struts lowered approx 1". No visual leaking from any suspension bushings in the front end. Car was recently aligned 2x by 2 different places, both saying it was perfectly in spec.
Where would you look to and/or replace next? Track day coming up soon and want to be in good shape
Thanks!
