TwinTurbo.NET: Nissan 300ZX forum - Just a quick caveat, make sure the oil on the turbos isn't
Subject Just a quick caveat, make sure the oil on the turbos isn't
Posted by SirpriZ on May 22, 2015 at 9:31 PM
  This message has been viewed 514 times.
In Reply To Re: Leaky valve seal symptoms should show up on decel. You posted by Quick_Z on May 22, 2015 at 08:58 PM
Message from an oil fitting (sure you already checked that). Leaky seals can leak into both the compressor and turbine side. You know, I'm not sure about the oil/debris reaching the plenum without leaving any residue in the pipes. Mark
