TwinTurbo.NET: Nissan 300ZX forum - Leaky valve seal symptoms should show up on decel. You
Subject Leaky valve seal symptoms should show up on decel. You
Posted by SirpriZ on May 22, 2015 at 3:28 PM
  This message has been viewed 651 times.
In Reply To Why is there oil in the plenum even after deleting pcv's? posted by Quick_Z on May 22, 2015 at 06:17 AM
Message should see blueish smoke when you let off the throttle. On vacuum, the oil is sucked past the seals into the cylinder and out the exhaust. It's common for turbocharged cars to have a light coating of oil on the piping over time, which might account for some of the accumulated crap in the plenum. I don't know what's causing the debris to be deposited (you said your turbos are leaking, sounds like bad turbo seals. Could the trash be seal debris? Just a guess.). Bad seals can also cause blue smoke on decel. Mark
