TwinTurbo.NET: Nissan 300ZX forum - i never did all of that pressure to piston stuff.
Subject i never did all of that pressure to piston stuff.
Posted by LivinTheDream on May 21, 2015 at 11:39 PM
  This message has been viewed 352 times.
In Reply To Re: Did you remove the auto-tensioner stopper bolt? posted by flashstar on May 21, 2015 at 12:36 PM
Message What works for me is I use Allen keys as my tool for measuring. Using say a 3mm gap I just barely put any presure against the belt with the tensioner when I install it. Tighten the bolts all the way. Then once I pull the stopper bolt it opens to about 4.5mm. Rotate repeatedly and fine. If it changes its usually is maybe a mill to tight or lose and then I just apply a pinch more pressure on install or less. Don't touch no piston.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
