TwinTurbo.NET: Nissan 300ZX forum - Re: If I delete the EGR vacuum line wouldn't that prevent the
Subject Re: If I delete the EGR vacuum line wouldn't that prevent the
Posted by CarolinaZ_TT on May 20, 2015 at 12:38 PM
  This message has been viewed 305 times.
In Reply To If I delete the EGR vacuum line wouldn't that prevent the posted by YlwPrlZTT on May 18, 2015 at 09:52 PM
Message Is it safe to say you have the plenum off?
I was at the same point you are and was going to accept that I had to leave the feed tube. Eliminating that tube with the motor in is possible. I used a hand saw to cut the tube (took a while) and bent it enough to slide the box end of a stubby wrench over the feed tube nut. Applied PB Blaster liberally. Then I used a breaker bar pressed against the wrench and rubber mallet to break the nut loose. It was rewarding to say the least. Plug with the delete kit, drink a beer, and move on to the next project.
I <3 Boost.
I wave at all 350/370Zs and less than 1% wave back. WTF?
