TwinTurbo.NET: Nissan 300ZX forum - Pressing in is fine. Use longer screws to make it easier
Subject Pressing in is fine. Use longer screws to make it easier
Posted by jzack on May 19, 2015 at 8:07 PM
  This message has been viewed 299 times.
In Reply To also any tips on installing injectors? They are very posted by YlwPrlZTT on May 19, 2015 at 04:49 PM
Message and replace for final install. Just be sure to tighten evenly when pressing in....did all mine that way. Use Vaseline lube too.
Not a bad idea to pressure check the rail for leaks. Did mine with air and a pressure gauge. Some hook up the fuel lines with plenum off, pressurize and check that way.
