TwinTurbo.NET: Nissan 300ZX forum - stumble/hesitation problem
Subject stumble/hesitation problem
Posted by Potacka on May 18, 2015 at 5:34 PM
  This message has been viewed 353 times.
Message Im having a problem with my 91 N/A and really need some help.
I'm getting stumbling and loss of power at around 2,000 rpm while driving, just Revving when not in gear it's barely noticeable. Once I get over 3,000rpm seems to smooth out.
Engine was running fine last fall, over the winter did the following:
Changed radiator
Pulled plenum
Disassembled and cleaned IAA and air regulator
Det. Sensor relocate
New headers
Replaced all coil paks
When driving it feels like a cylinder not firing. First drive was only a slight problem, wasn't even sure if It was there or not. Next time out the problem started after 5-10 minutes of driving. Now it's all the time.
I've done the following
Power balance test, no problem found
Changed all coil paks back to old known working units, no change
Checked ecu, no error codes.
Set throttle bodies per the service manual
Set the idle
Tested and set TPS
Checked hose connections, pcv, IAA etc.
Pressure tested intake and fixed all leaks
Replaced leaking air regulator with new
Changed CAS
Tested and cleaned MAF
Replaced O2 sensors
Tested injectors, ohm test and click test
Checked timing
Probably a few other things as well
After changing the CAS car ran much better maybe 90%, next time I drove it the problem was back.
What else should I be looking at?
Thanks,
Adam
