TwinTurbo.NET: Nissan 300ZX forum - As I've stated above, boost leak pressure test. IACV is new
Subject As I've stated above, boost leak pressure test. IACV is new
Posted by ZTicket(Dallas) on May 14, 2015 at 10:39 AM
  This message has been viewed 350 times.
In Reply To When idle, your RPM's should increase when you turn posted by FrozTTy on May 14, 2015 at 10:28 AM
Message and cleaned/working properly i.e. Idle adjusts properly w/Air conditioning/Cold Start function works/Idle pops back up when letting off gas coming to a stop (as it should). IMO un-metered air is getting into the system somewhere not allowing me to adjust idle below 1000rpm. I use NProbe for diagnostics. I don't remember the idle fluctuating when turning the wheel before. I've owned the car since 2000.
