TwinTurbo.NET: Nissan 300ZX forum - Yup, my detonation sensor wire corroded 1" back
flashstar
on May 13, 2015 at 1:02 PM
more benefits to a new harness than just connectors
posted by LivinTheDream
on May 13, 2015 at 11:25 AM
Same story for many of my connectors. The plastic wire insulation also becomes brittle over time and can break. Just replace the whole thing to avoid weird electrical gremlins in the future. Delete the PTU sub-harness while you're at it! ;)
First plenum pull, any suggestions for the harness?
YlwPrlZTT
21:57:51 05/12/15
Re: First plenum pull, any suggestions for the harness?
Bo (Houston)
22:26:20 05/12/15
Cut Out the Old Harness and Install a New One
flashstar
22:50:41 05/12/15
Can it be done with the engine in? (n/m)
YlwPrlZTT
22:55:07 05/12/15
Yes, but many suggest removing transmission
spicyZ
10:54:18 05/13/15
I've done the entire job with only the plenum removed
flashstar
12:31:23 05/13/15
Did you have to pry bar the hole in the firewall
spicyZ
09:37:34 05/14/15
Nope, I just wrapped the connector tightly with electrical
flashstar
12:28:51 05/14/15
You could do the ultimate cheap route.
Goldchocobo
23:03:51 05/12/15
Assuming the junker connectors don't fall apart>>
ZUL8TR
04:08:56 05/13/15
I will definitely try going that route. Thank you. (n/m)
YlwPrlZTT
08:47:54 05/13/15
When doing injectors see link>>>>>>>>>>>>>>
ZUL8TR
09:08:29 05/13/15
Just find the nice ones
Goldchocobo
09:22:54 05/13/15
LivinTheDream
11:25:54 05/13/15
Yup, my detonation sensor wire corroded 1" back -
flashstar
13:02:45 05/13/15
What is the benifit of deleating the PTU? (n/m)
ZUL8TR
13:32:29 05/13/15
"sub harness" because less corrosion points (n/m)
LivinTheDream
13:57:06 05/13/15
and it's off!! I feel accomplished :-)
YlwPrlZTT
23:16:33 05/13/15
good job, now get some tape over those intake ports (n/m)
ZUL8TR
04:32:01 05/14/15
Android300zx
04:48:34 05/17/15
