TwinTurbo.NET: Nissan 300ZX forum - cleaning engine after blow hg/coolant oil mix
Subject cleaning engine after blow hg/coolant oil mix
Posted by LivinTheDream on May 12, 2015 at 7:37 PM
  This message has been viewed 321 times.
Message Hey guys I'm working on an engine that suffered a blow head gasket. The oil and coolant ended up mixing. I was wondering if after replacing the head gasket should I spray what I can down with brake parts cleaner to get that chocolate milk looking stuff off or just reassemble and flush the engine? I'm afraid to remove oil from places that need it and cause metal to metal startup in some areas.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
