TwinTurbo.NET: Nissan 300ZX forum - dead miss help
Subject dead miss help
Posted by jhop1988 on May 12, 2015 at 7:20 PM
  This message has been viewed 298 times.
Message Ok so I did balance test an it's #6 that's not hitting spark check compression check 153 psi I ohm the injector on it was 20 ohms. But before I just put a water pump on ran ok it prior. It did hesitate under moderate throttle in mid rpms. Just looking for some back up on that's the problem. I'm do not wanna buy injectors an pull the manifold an be wrong again it did ohm 20. If so is there a easy way around it.
