TwinTurbo.NET: Nissan 300ZX forum - 100% DC is a limit of the injectors, not the pump
Subject 100% DC is a limit of the injectors, not the pump
Posted by ChristopherTheOne on May 11, 2015 at 5:15 PM
  This message has been viewed 379 times.
In Reply To stock tt Fuel pump limit posted by TwinTurboByrd on May 11, 2015 at 10:08 AM
Message The injectors are designed to deliver a metered charge of fuel from a rail that's approximately 45.5psi above manifold pressure. The ECU times the injector pulses based on this basic assumption. If you raise the rail pressure, you'll still hit 100% DC because the ECU doesn't know you changed anything...you'll just run rich all the time.
The answer is to use higher-flowing injectors, and reprogram the ECU accordingly.
The stock TT uses injectors rated for 370cc/min, and they'll get maxed out around 15-ish psi of boost.
Replacing them with 555cc (or 740cc) units allows the ECU to deliver the same fuel charge with a pulse that's 33% (or 50%) shorter than stock. It also means that at 100% duty cycle, they're delivering 1.5x (or 2x) as much fuel as stock, so you can push a lot more boost without overloading the fuel delivery system.
The stock pump can support builds of ~700whp...if you go bigger, some guys have been known to run dual stock pumps, others have replaced it with an aftermarket setup.
