TwinTurbo.NET: Nissan 300ZX forum - stock tt Fuel pump limit
TwinTurboByrd
on May 11, 2015 at 10:08 AM
My injector duty frequently hits 100% duty cycle. Is this an indication I need to replace fuel pump?? This is the only part of the car I have never replaced. Im assuming its just a stock TT pump. Any input?
stock tt Fuel pump limit -
TwinTurboByrd
10:08:43 05/11/15
It means the injectors are max out unless you have 650whp (n/m)
puchy
11:37:14 05/11/15
100% DC is a limit of the injectors, not the pump
ChristopherTheOne
17:15:00 05/11/15
Re: 100% DC is a limit of the injectors, not the pump
TwinTurboByrd
18:40:17 05/11/15
What ECU tune are you using? (n/m)
ChristopherTheOne
23:44:18 05/11/15
Re: What ECU tune are you using?
TwinTurboByrd
11:19:37 05/12/15
then you are running too rich or your fuel pressure is off (n/m)
ztunerz
08:53:00 05/15/15
TwinTurboByrd
18:40:51 05/11/15
What are you using to monitor/measure injector DC? (n/m)
spicyZ
10:56:43 05/13/15
