TwinTurbo.NET: Nissan 300ZX forum - Add change the thermostat, if not accuratly setting the >>
Subject Add change the thermostat, if not accuratly setting the >>
Posted by ZUL8TR on May 11, 2015 at 3:25 AM
  This message has been viewed 336 times.
In Reply To I would posted by FrozTTy on May 09, 2015 at 09:05 PM
Message coolant temp the ECU will affect injector pulses and fuel flow. This in combination with a marginal injector(s), dirty MAF, etc could be related to your issue.
Also look into the injector connectors, the internal wires at the connector can get corroded and affect injector voltage signal, noticed that when I up graded to new style injectors and connectors. Use dielectric grease in connectors.
ZUL8TR in Orlando,FL
