TwinTurbo.NET: Nissan 300ZX forum - Sounds like too much runout...either clutch or H20 pump
Subject Sounds like too much runout...either clutch or H20 pump
Posted by ZXoltan on May 09, 2015 at 6:15 AM
  This message has been viewed 295 times.
In Reply To slight clutch fan wobble under 1k rpm??? posted by LivinTheDream on May 08, 2015 at 10:05 PM
Message Not to scare you but possible it could tear up the water pump over time, so def best to be cautious.
Best way to check runout is with a dial gauge mounted in a holder. Harbor freight has an inexpensive setup. Can use it for multiple purposes around the car wheel hubs, brakes, etc.
Not impossible that its the fan itself, but not likely.
