TwinTurbo.NET: Nissan 300ZX forum - slight clutch fan wobble under 1k rpm???
Subject slight clutch fan wobble under 1k rpm???
Posted by LivinTheDream on May 08, 2015 at 10:05 PM
  This message has been viewed 327 times.
Message Hey guys just changed the water pump and alternator bearings for starters but even prior I noticed this issue. The fan, looking at it from the side, spins perfect during initial start up when the rpms are between 1500-1000. But once the idle lowers to sub 1000 the fan starts to wobble very slightly.
If I hold the fan clutch (car off) and rock it firmly I get less than 1/16 of play with the new pump.
I was chasing a squeak and now I feel its from the belt when the fan wobbles.
Thanks guys.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
