TwinTurbo.NET: Nissan 300ZX forum - I'm not positive, but if you disconnect the hood security
Zuberman
on May 08, 2015 at 1:35 PM
THANKS for all the suggestions, the only issue is >>
posted by stockplayerz(nyc)
on May 06, 2015 at 01:59 PM
switch, that might disable the alarm system or prevent it from setting in the first place.
As affordable as they are these days, you might consider an aftermarket alarm system?
HELP!! 10A fuse keeps blowing out instantly >>
stockplayerz(nyc)
09:11:54 05/01/15
One thing to check, the stock Bose system had powered amps
jzack
10:50:47 05/01/15
oh very interesting- definitely a starting point to check >>
stockplayerz(nyc)
11:06:01 05/01/15
look for a lonely wire thats just taking up space (n/m)
LivinTheDream
15:24:35 05/01/15
Michael, had a similar issue with the 10 amp fuse,
ttz'in (norcal)
19:23:24 05/01/15
Thanks- are the connectors under the footwell or in door? Tx (n/m)
stockplayerz(nyc)
06:04:54 05/02/15
Re: Thanks- are the connectors under the footwell or in door? Tx
ttz'in (norcal)
13:54:23 05/02/15
UPDATE >>
stockplayerz(nyc)
06:21:51 05/02/15
FOUND IT! One step closer >>
stockplayerz(nyc)
09:40:26 05/02/15
Actuator and door wiring is different between the years
ZXoltan
10:03:07 05/02/15
Thanks- this may be more challenging than I thought >>
stockplayerz(nyc)
10:46:19 05/02/15
Should have kept the wiring and guts from your old door :-O
ZXoltan
11:04:30 05/02/15
yes- lesson learned >>
stockplayerz(nyc)
11:57:12 05/02/15
May also affect the security system ?
ttz'in (norcal)
13:57:38 05/02/15
Get this from him. Be done with it :) (n/m)
Zuberman
21:51:02 05/02/15
Are u sure the 90 2+2 is exactly same as 91 TT ?
ZXoltan
10:24:30 05/04/15
I think your question is for ttz'in since he is the one who
Zuberman
11:32:42 05/04/15
For both of you since you said "get this from him" lol (n/m)
ZXoltan
13:10:50 05/04/15
Not speaking for anyone else, but what I would do is print
Zuberman
13:46:26 05/04/15
stockplayerz(nyc)
13:59:56 05/06/15
I'm not positive, but if you disconnect the hood security -
Zuberman
13:35:53 05/08/15
Not sure about a '91TT being the same, but
ttz'in (norcal)
13:46:27 05/04/15
