TwinTurbo.NET: Nissan 300ZX forum - Try bleeding the clutch line?
Subject Try bleeding the clutch line?
Posted by ChristopherTheOne on April 29, 2015 at 11:49 PM
  This message has been viewed 288 times.
In Reply To having clutch issues when the car is hot posted by RonaldJ55 on April 29, 2015 at 04:09 PM
Message There could be air in the line, expanding as the fluid heats up.
The friction material of the clutch itself shouldn't be affected by thermal changes, nor should the spring rate of the pressure plate. That points to the actuation mechanism being the likely variable.
