| Subject |
Pull the plenum, label everything, take B4 photos>> |
| Posted by |
ZUL8TR on April 29, 2015 at 3:58 PM |
This message has been viewed 289 times. |
| In Reply To |
fuel injectors posted by fcap2002 on April 28, 2015 at 08:48 AM |
| Message |
clean up all carbon on plenum, dremel all 6 injectors areas for future injector replace, replace all rubber hoses underneath plenum and at rear, reseal the exhaust covers with high temp O2 safe silicon, new gaskets for the intake covers, if early pintle injectors upgrade to pintleless and upgraded connectors, clean throttle bodies, check all injectors on looped fuel rail in water bucket with 50 psi air pressure for no leaks B4 install on engine, check fuel regulator and damper, clean idle control motor unit. B4 start disconnect the battery. Go slow and be patient.
ZUL8TR in Orlando,FL |
| Follow Ups |
Post a Followup |
