TwinTurbo.NET: Nissan 300ZX forum - Notch on the Chip to the Center of the Board
Cjw3
on April 26, 2015 at 5:29 PM
Re: Good Call on the Chip..
posted by Placuch
on April 26, 2015 at 01:15 PM
http://www.twinturbo.net/nissan/300zx/forums/technical/view/1147286/Chipping-the-ECU.html
Some pictures here..
Cj
Crank, no start after injector upgrade. Help! Desperate!
Placuch
00:28:35 04/26/15
You can add a ground net system and it will take care >>
ZUL8TR
04:01:59 04/26/15
Re: You can add a ground net system and it will take care >>
Placuch
10:07:58 04/26/15
Extra grounds are like chicken soup they could improve >>
ZUL8TR
13:20:38 04/26/15
A properly wired car won't need a grounding system. (n/m)
Nate (NoVA)
23:40:30 04/27/15
Pull the Crossover Tube, and find your Grounds
Cjw3
09:16:16 04/26/15
Re: Pull the Crossover Tube, and find your Grounds
Placuch
10:01:09 04/26/15
EFI harness has group of three ground wires
ttz'in (norcal)
11:37:27 04/26/15
Cjw3
12:09:24 04/26/15
Placuch
13:15:30 04/26/15
Notch on the Chip to the Center of the Board -
Cjw3
17:29:45 04/26/15
Re: Notch on the Chip to the Center of the Board
Placuch
21:03:43 04/26/15
Generally the Chip is toast.. Board is fine..
Cjw3
21:23:17 04/26/15
Re: EFI harness has group of three ground wires
Placuch
13:07:01 04/26/15
Placuch
20:47:43 04/26/15
Sounds like EFI harness grounds are all good.
ttz'in (norcal)
20:20:42 04/27/15
Re: Sounds like EFI harness grounds are all good.
Placuch
23:56:38 04/27/15
Placuch
07:47:54 04/28/15
I fixed it!
Placuch
07:30:01 04/29/15
