TwinTurbo.NET: Nissan 300ZX forum - Re: EFI harness has group of three ground wires
Subject Re: EFI harness has group of three ground wires
Posted by Placuch on April 26, 2015 at 1:07 PM
  This message has been viewed 456 times.
In Reply To EFI harness has group of three ground wires posted by ttz'in (norcal) on April 26, 2015 at 11:37 AM
Message So i've got the one on the passenger side rear top of the plenum connected. It separates from the efi part of the harness before coil and connectors separate from it. I also have the one the driver's side hooked up, the one next to IAC that actually has 2 wires bolted in one location. The one you mentioned from fuel rail to the lower plenum I guess would be the missing one. What worries me that since I didn't notice it when installing the plenum, it might be tucked in somewhere underneath it now... But would not having that ground connected still allow the injectors to click when I rotate the CAS? Or would it affect the fuel delivery system in any other ways? Maybe it is just an extra/redundant ground? Because the injectors click. I will check on the chip.
Thank you for your input!
