TwinTurbo.NET: Nissan 300ZX forum - Re: You can add a ground net system and it will take care >>
Subject Re: You can add a ground net system and it will take care >>
Posted by Placuch on April 26, 2015 at 10:07 AM
  This message has been viewed 358 times.
In Reply To You can add a ground net system and it will take care >> posted by ZUL8TR on April 26, 2015 at 04:01 AM
Message Thank you for your response.
That's an idea but I'm not a 100% sure it would address my problem directly. If I make the grounds from the engine and body to the battery better, it still would not change the fact some component/system may not be connected to those new improved ground or any ground for that matter. That's what I suspect happening at least. But it gives me an idea. Trace the ECU grounds and splice extra grounds into them leading to good grounding points.
